Hi all.. New here sorry if i'm a noob but need some advice on upgrading gpu.
I am currently using a Palit Gtx 970 jetstream on a msi b150m mobo. Looking to upgrade to zotac gtx 1070 mini but got a few concerns with size and power connector
zotac(dot)com/us/product/graphics_card/zotac-geforce%C2%AE-gtx-1070-mini-0#spec
palit(dot)com/palit/vgapro.php?id=2407&lang=en&pn=NE5X970H16G2-2043J&tab=sp
Zotac has Dual 6-pin to 8-pin PCIe adapter and is 210mm x 122mm
Palit is 6-pin X2 and is 247mm x 126mm
Does this mean fitting the Zotac will have issues with connectivity at the back? Like will I have to refit my entire mobo in the casing the sit the display inputs nicely at the back of my casing??
A friend of mine installed for me last time so I'm not too sure..
