Need some help
Tsunayoshii
Recently i just bought my diy pc but my cpu temp on idle is around 50+ i wonder is there something wrong or should i buy a cpu cooler?
My specs:
MSI z97 gaming 5 + i5-4960
MSI GTX 970 TF
WD black 1tb
SILICON POWER V60 240GB
G.SKIL RIPJAWSZ 1600MHz CL9 8GBX2
SEASONIC M1211620 MODULAR 620W
Fractal Design R5 with window case
running 2 monitor 1 running at 1920x1080 and 1280 x 1024
finalforce
Actually 50deg C is quite normal and shouldn't be a cause of worry. However, if you want to bring it down, can buy a CPU cooler
shadow84
Do get MX4 thermal paste.. U can get it at $11.90 from vrz, add 50 cents for postage. Better than getting frm sls which starts from $16-18.
tungsten2
My specs:
MSI GTX 970 TF
WD black 1tb
50 degree c on idle is a bit on the high sideif you did not overclock.
It is better you re-seat your heatsink and re-apply the thermal paste. Normal one will do.
