Need some opinions. Why does my computer keep restarting?
chanjw
Hi all! Need some help / opinions here..
Problem: 5 year old PC restarts after powered up for ~2 seconds.
How it happen: was using my desktop for some light surfing when it suddenly restarts itself. And it has been that way until I turn off the power.
What I have done / actions performed so far:
1) Clean as much dust as possible off the fans, and places where dust collects.
2) Did the paper test clip on the PSU.
3) Powered up 1 component at a time to test that they are working.
4) Check for out-of-shape capacitors on the mother board.
Results:
1) PSU pass paper clip test.
2) Powered up all components at once except motherboard and fans connected to motherboard. No restart.
3) No "blown" capacitors found.
Components:
1) Mobo - MSI P43 Neo3
2) CPU - AMD Athlon? 8840 series? Don't remember. Quad core.
3) GPU - Powercolor Radeon 4850 HD
4) PSU - Andyson 500W (which model exactly, not sure).
5) HDD - WD Caviar Blue 320GB
6) RAM - Kingston 2GB x2
I know my system is old. And likely culprit is either the mother board or cpu. Please give some opinions on why my desktop is behaving this way.
allhomme
If visual check of mobo components is good, see if can get a psu of similar capacity to try.
