Need some pro recommendations and comments - dilema
kyteo79
Hi seniors need some help and pointers ;
Yoga Slim 7 Pro 14ITL5
Part Number: 82FXCTO1WW
Ships within 2 weeks.
Save for Later
Non-Member PriceSG$1,897.00
System Specs: ( Edit )
Processor : Intel Core i7-1165G7 Processor (2.80GHz, up to 4.70GHz with Turbo Boost, 4 Cores, 8 Threads, 12MB Cache)
Operating System : Windows 10 Home 64
Operating System Language : Windows 10 Home 64 Traditional Chinese/Simplified Chinese/English
Microsoft Productivity Software : Microsoft 365 Personal
Memory : 16GB LPDDR4X 4266MHz Onboard
Solid State Drive : 1TB Solid State Drive, M.2 2280, PCIe-NVMe, TLC
Display : 14.0'' 2.8K(2880x1800) IPS Glare 400nits 90Hz 100%sRGB Non-Touch with Glass
Graphic Card : Integrated Graphics
Camera : IR&HD Camera No Mic
Microphone : Array Microphone
Color : Slate Grey
Keyboard : Backlit Keyboard Slate Grey English
Wireless : Wi-Fi 6 2x2 AX, Bluetooth Version 5.0 or above
Athena Certified Model : Evo Certified
Surface Treatment : Anodizing Sandblasting
Palmrest : AL
Battery : 4 Cell Li-Polymer Internal Battery, 61Wh
Power Cord : 65W AC Adapter Slim (3pin)-UK (USB Type C)
Language Pack : Publication-English/Simplified Chinese/Traditional Chinese
Warranty : 1 Year Carry-in
or
Yoga Slim 7 Pro 14ARH5
Part Number: 82LACTO1WW
Save for Later
Non-Member PriceSG$1,707.00
Processor : AMD Ryzen 7 4800H Processor (2.90GHz, Max Boost up to 4.20GHz, 8 Cores, 8MB Cache)
Memory : 16GB DDR4 3200MHz Onboard
Color : Slate Grey
Palmrest : AL
Power Cord : 95W AC Adapter Black (3pin)-UK (USB Type C)
(minus 100 for the 2.2k monitor)
Same item with 2.2k monitor selling at 1599 at HN with 2 yr onsite warranty
(exclude the office 365)
Which one should i go for ?
Am also considering the Asus zenbook below 2k types ... not too sure if would compare apple to apple ...
ckctam
Can you wait? Ryzen 5000 just launch. It is much better than ryzen 4000.
BTW what is your criteria or needs to your laptop.
chaiscool
Don’t those H cpu consume for power and hotter. Hopefully non gaming laptop can cool them properly to avoid throttling. Also, shorter battery life.
Why not get non pro with U cpu?
kyteo79
Just basic usage with photos video storage.
Dun need r5000 as it would be too costly.
Yes t1 is overkill but laptop housekeeping such as transferring out data would be every year or so. That’s y need big HD.
As u could see my budget is max 2k and would like the best what I could squeeze out.
Zenbook is about that range as well but the dual screen is abit too modern for me and not too sure if Asus is as good as what it should be with the negative comments in the forum
Another is msi modern at 1400 which is pretty attractive priced so I am not too sure which bullet to bite.
kyteo79
Thanks I hope I get your terminology right as in get processor or Vivo slim rather than Vivo slim pro ?
Not really up to date on these processor stuffs.
On rig, it is gg to be a shared laptop with my partner so like abit stylish and not too big for my other half to drag around
natas
Which zenbook u looking at? Look at UX425 or UM425... good enough for daily usage, light and long battery life. If 1TB ssd is not enough, get external ssd or hdd.
Fujitsu uhx is around your budget.
ckctam
Is 1TB enough for you? I've find 2 tb is a good size. I ain't a photographer but I need the space to back up pics and videos of my kids. Lol
If you have the cash, a 2 TB ssd can last you for a long time.
kyteo79
ASUS ZenBook 14 UX434FQ - S$1798 (saw this offer) - Not too sure if cooling is an issue ?
Processor
Intel® Core™ i7 10510U/Intel vPro CPU Processor,
Operating System
Windows 10 Home -
Memory
16 GB LPDDR3 2133MHz SDRAM Onboard memory
Display
14.0" (16:9) LED-backlit FHD (1920x1080) 60Hz Glare Touchscreen with 72% NTSC with wide 178° viewing angles
With WideView Technology
Graphic
NVIDIA® GeForce® MX350 , with 2GB GDDR5 VRAM
Storage
Solid state drive:
1TB PCIe® Gen3 x2 SSD
Keyboard
Illuminated chiclet keyboard
Card Reader
Multi-format card reader (SD/MMC)
WebCam
IR camera
Networking
Wi-Fi
Integrated Wi-Fi 6 (802.11 ax (2x2))
Bluetooth
Bluetooth® 5.0
Interface
1 x Type-A USB2.0
1 x Type-A USB 3.2 (Gen 2)
1 x Type-C USB 3.2 (Gen 2)
1 x HDMI
1 x micro SD card
1 x audio jack combo
Audio
Built-in 1 W Stereo Speakers with Microphone
Support Alexa
Smart AMP
Supports Windows 10 Cortana with Voice
Harman Kardon
Battery
3 -Cell 50
mAh Polymer Battery
Power Adapter
Plug type :ø4 (mm)
Output :
19 V DC, 3.42 A, 65 W
Input :
100 -240 V AC, 50/60 Hz universal
Dimensions
NB:
319 x 199 x 16.9 ~18.2 cm (WxDxH)
Weight
NB:
1.15 kg ~ 1.26 kg with battery
Security
BIOS user password protection
TPM (Trusted Platform Module)
USB security lock cable
fTPM (Firmware-based Trusted Platform Module)
Built-in APPs
MyASUS
McAfee's free one-year offer
MyASUS feature
System Diagnosis
Battery Health Charging
Fan Profile
Splendid
Function Key Lock
AppDeals
Link to MyASUS
chaiscool
Processor
Operating System
Windows 10 Home -
Memory
Display
Graphic
Storage
Solid state drive:
Keyboard
Card Reader
WebCam
IR camera
Networking
Wi-Fi
Bluetooth
Bluetooth® 5.0
Interface
1 x Type-A USB2.0
1 x HDMI
1 x micro SD card
Audio
Support Alexa
Smart AMP
Harman Kardon
Battery
3 -Cell 50
mAh Polymer Battery
Power Adapter
Plug type :ø4 (mm)
Output :
Input :
Dimensions
NB:
Weight
NB:
Security
Built-in APPs
MyASUS
MyASUS feature
System Diagnosis
Fan Profile
Splendid
Function Key Lock
AppDeals
Link to MyASUS
Why not get the newer um425 / ux425. Cheaper, more compact and bigger (67wh) battery. Usb c charging too instead of the gimp display only in ux434
kyteo79
True true
Was thinking of the screen ...
Seems no Lenovo yoga fans
chaiscool
True true
Actually would recommend yoga if you can wait for discount. It’s cheaper but also thicker and heavier.
Also, some reviews seem to say that yoga (non pro) despite having a smaller battery can outlast the zenbook.
kyteo79
If money was not the issue would you go for yoga slim i7 or amd7
(Non pro) or still stick with Asus zen book as per recommendation
chaiscool
MacBook Pro 13 haha ... if Windows isn’t a requirement.
If price is not an issue, is weight / battery / size important? Cause if none of it matter, then just get the cheapest which is yoga. Asus is more expensive but a bit lighter, smaller and bigger battery.
