Need suggestion for Work Laptop
imxuan
These are the given specs,
Intel Core - i7
512 GB
16GB RAM
Windows 10 Pro
Budget up to 2.6k
Any suggestion?
Lex1989
With S$2.6K pretty much easy to get such spec you wanted.
But now it boils down to the aesthetic of the laptop you would prefer.
Weight / Screen size etc.
royfrosty
Actually if work is concern, i will recommend ultrabook categories if you are commuting to work everyday, meeting clients, or perhaps going to places to do presentation.
Laptops like fujitsu UHX, LG gram or any laptops under the ultrabook category that is below 1kg. These category is best suited for the above needs.
Although there are better laptops in 1kg to 1.4kg category, they tend to be a little heavy if you gonna carry a long time. But if you just head to office and back home, then this weight is manageable. YMMV.
Henabi
Thinkpad or
Dell XP
Hp Envy
since its for work… the warranty also important. Go for those which provide Premium Onsite servicing, either same-day or Next business day
Vassago
Thinkpad or
Dell XP
Hp Envy
Agreed, Get the better warranty. for Peace of mind.
