Need to build a m-ITX PC.
King Alonso
Hello all,
I need recommendation for building a office computer that is small and doesn't take up too much space.
Application wise, MS Office, surfing nets, youtubes, movies. No need a GPU for gaming but still require room for upgrade in the future will be good.
Hardware i'll need a SSD at least 500gb and a monitor of screen size at least 23"
I'll prefer to get all the parts in 1 shop as i might be claiming for PIC.
Thank you. my budget is $1000.
rvyne7
I just build new m-itx setup last 2 weeks ago.. I've use Node 202 casing wont be sharing specs coz its bit higher than your budget but its perfect size almost as big as your console + can fit 1 single standard GPU
singupingu
CASE: Fractal Design Node 202 ($129)
MOBO+CPU: MSI H110i Pro AC + Pentium G4560 ($211)
RAM: Kingston Valueram DDR4 2133MHz 1X8GB ($85)
PSU: FSP SFX 450W Bronze ($99)
SSD: PNY CS1311 480GB ($219)
MONITOR: AOC M2461FWH 23.6" ($169)
TOTAL: $912
Prices quoted from PC Theme, excluding any discount given by shop.
OS can be bought from Carousell.
Assembly fee I think is $20 iirc. You gotta check with shop if you intend to ask them assemble for you.
Would suggest you get i5-7500 for better future proofing. But it will exceed your budget for sure. So up to you to decide.
Sent from Overpowered Phone Mark III using GAGT
