Need to reapply Thermal paste for idled PC?
sgdevilzz
Hi,
Just reopened my PC after 1 LONG year of idling in the storeroom.
I want to know if I should reapply the paste? Will the paste be dried after this long? I read online a lot of people don't change the paste for 2 years+.
Any suggestions?
Note: I have not power on the PC yet. Awaiting confirmation from the pros here ;)
Don
Op_Valkyrie
Hi,
Any suggestions?
Don
Can u check and post your current cpu temperature when u power on? U can also do a cross check online (comparison with similar cpu temp) to see if your temperature is norm before deciding.
IMO u shouldn't need to change the TIM unless your rig is stored in a very low humidity for a long period of time. Singapore humidity quite high...
sgdevilzz
IMO u shouldn't need to change the TIM unless it been a very low humidity for a long period of time. Singapore humidity quite high...
How to check cpu temp?
Op_Valkyrie
Through bios - simple way
Unless u wanna run your PC for a while playing games or bench to see the real stretch of your TIM delta T then u need some tools - u can Google for those online easily...
sgdevilzz
Tried powering on my PC but nothing coming up on the monitor, can't go bios. Fans still working though. I noticed there's no beep.
Op_Valkyrie
I don think that got to do with TIM... If cpu overheat once u power on it will shutdown instantly... Fan shouldn't spin...
sgdevilzz
****.. Did I keep the PC for too long? It was working fine before I packed it up a year ago...
ZrE0_Cha0s
maybe u can list ur specs over here and see if others knows ur issues or not. :o
wwenze
Trivia: Vapor pressure of oil is independent of vapor pressure of water
chesterqw
Thermal paste is to fill the microscopic gap
You only care if it is dry if you were using toothpaste
sgdevilzz
My specs are
Asrock Z87 extreme4
CS650M
GTX 680
intel i5-3550
2x 8gb RAM
Windows 7
jtjt00
I think motherboard is gone liao, RMA if still under warranty.
hlots123
try take out ur ram sticks, use a soft pencil eraser to rub clean the rams' golden contact areas...
sgdevilzz
But back to my first question. Should I reapply the paste? It's actually been 2 years since I first applied it.
darkarn
Check the CMOS battery too; i have similar cases that are solved only when I replaced it.
