Need Upgrades Suggestion for my current Rig
kEnsAn
Hi all!
I need some suggestions to go about an upgrade for certain parts of my aging pc :(
My number 1 requirement is be able to play Dota 2 at maximum graphics settings, 1680 x 1050 resolution with constant frame rates around 60fps or higher.
Sadly my budget is only around $200 - $600..
Here's my current rig (also listed at the side: my profile):
Intel C2D E8500 + EP45-UD3P
Gskill 1600mhz 4gb
Palit Radeon HD 4870
Veloci-raptor 150GB
SeaSonic M12II 750W
Coolmaster CM590
Looking forward to your replies :))
royfrosty
If your monitor is going to be at that max resolution. I think the best option is for you to upgrade your monitor also.
Dell s2340l 23 inch IPS panel ~ $219
Asrock b75m dgs + i5-3350p ~ $271
Adata 8gb 1600mhz ~ $85
Total $575.
If your GPU cannot handle 1080p best option for it is a powercolor 7750 or 7770.
Lethal
7750 is in the same category as 4870 in graphics hierachy chart.
don't think it will be much of a difference.
can consider upgrade to i5 first while using the same graphics card, it will help to increase ur fps more
Jian19
Ish ur ram ddr3 ?
i5-4570 + Msi b85m g43 ~ $356
Msi 7850 tf 2gb ~ $245
$601 from tradepac ask for discount and DIY
Or
i5-3350p + Asrock b75m dgs ~ $271
Adata 8gb ddr3 1600 ~ $85
Total ~ $601
kEnsAn
Thanks for the replies guys!
My fps is only around 20-40 with everything maxed out (shadows AA and stuff), and it gets pretty laggy during 5v5 team fights.
I think I'm mistaken about my ram, its actually Crucial Ballistix 4GB (PC2 6400 omg!).
Based on your recommendations, I guess most likely I have would have to change my cpu+mobo+ram as well as graphic card to run dota 2 at max settings.
Do you guys think I can go for just a single upgrade of graphic card to maybe GTX760 or R9 270? will my cpu be limiting the graphic performance?
P.S: Actually I've tested my HD 4870 with i7-950 cpu before, I still couldn't play dota 2 smoothly on max settings..
Jian19
Hoot mine 2nd suggestion, ur current CPU will bottleneck gtx760
royfrosty
If you only playing dota 2 a 7770 will do the job. Whats more your monitor resolution only 1650 x 1050.
I think the much worth while upgrade will be a Full HD monitor with a 7770.
Unless you are playing other games then most probably can do without the monitor.
