Need urgent help on a rig
Bishamonten
Bishamonten
Why must run at 3.4ghz ? :s22:
Budget ? Usage ?
I'm not sure why 3.4ghz and above
that's the requirement they wanted.
Budget is around 1.3k to 2k you think doable?
Usage for multiple display that's why the graphic card. they using it on 6 monitor
shadow84
Who is the 'they'? Your work??? Myabe list out what you intend to do with your rig, and your budget as well.
jtjt00
I don't think easy to find Powercolor HD7870 2GB with 6 mini display ports.
Bishamonten
They are so call client , the graphic card spec is by them. they needed a pc system to display 6 monitor so they can monitor a lot of graph at a time? mostly webbase or by their own software i guess.
3.4ghs and above
16gb ram
1tb hdd
is the other requirement.
budget i guess below 2k , is it doable?
actually is a sai gang thrown to me they ask me to go simlim ask people to spec out a system but i'm clueless.
MoneyFace =p
3.4ghs and above
16gb ram
1tb hdd
Trading stocks is it?
Jian19
i5-4670 + Msi b85m g43 ~ $357
Crucial 8gb ddr3 x 2 ~ $180
Wd blue 1tb ~ $76
Powercolor 7870 Eyefinity 6 ~ $440
Seasonic s12g 550w ~ $99
Samsung oem drive ~ $21
Fractal design arc mini r2 ~ $120
Dell u2412hm ~ $375
$1668 buy and DIY @ tradepac ask for discount, can bring to gs shop ask him help u assemble @ a fee if u not sure how to do it.
Optional ~ Plextor m5s 128gb ssd @ $130
shadow84
I think i saw it in one of the leaflet i brought back from sim lim , i think is $475 let me check again. thanks
What you see in leaflet may not reflect actual stocks in the shop. Cant be they update the leaflet every hour and say got stock or not.
But, best ot head down and take a look.
Also, your budget of $2k includes the 6x 24" monitors?
Bishamonten
Wd blue 1tb ~ $76
Dell u2412hm ~ $375
Hi Thank you very much , all these i can buy at tradepac at one go ? and where is gs shop?
Bishamonten
not included , just the system only , what will be a good full hd lcd monitor i can buy ?
shadow84
U2414H is good as it has VESA mounts. Can get those monitor stands which support 6x monitors and uses VESA mounts to secure. But, it depends on your arrangement.
GS shop is at #02-32.
shadow84
Also, not sure if tradepac will list out GST for you or not so as to let your coy get GST rebates or whatever. At least pc themes will state everything out for you. Play safe when dealing with such stuff.
Bishamonten
Ok thanks for all the help , i will take this spec and go pctheme and ask them to assemble for me. thanks thanks
Bishamonten
Btw do tradepac do assembling? because after going through the leaflet i onlly see tradepac has the graphic card @ 465
MoneyFace =p
3.4ghs and above
16gb ram
1tb hdd
CPU+MB: Intel Core i5-4440 + ASRock B85M Pro4 @ $328
Clock speed shouldn't be that sensitive since Intel Haswell processors are already speedily fast.
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB X2 @ $184
GPU: Leadtek GT 640 2GB [DDR3] X2 @ $220
For heterogeneous graphics, not SLI.
You can connect up to 8 monitors (4 on each graphics card), with enough VRAM capacity to draw out on these monitors.
SSD: SanDisk Ultra Plus 128GB @ $124
SSD will be super beneficial for these mission critical PCs.
HDD: Western Digital Blue 1TB @ $75
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Aurum S 500W [80 Plus Gold] @ $89
Great quality, highly-efficient PSU runs best on such PCs.
CASE: Sharkoon REX3 Value @ $69
Offers a whopping 6 USB ports, of which 2 of them are USB 3.0.
Total: $1110
Recommended:
DSP: Dell E2414H 24" LED [TN] @ $249
Trading environment should just prioritise on screen real estate, image quality unnecessary.
Optional:
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Buy and Build from Tradepac, #05-18.
Jian19
If pctheme dun have u can try tradepac / mynextcom for the graphic card
Then bring back pctheme ask them help u assemble
