im using thisgot sell those attached to the tap, don't have to use electricity.
just use the tap pressure to pump out the water.
not sure good enough or not
https://streamable.com/guj5zo
cheaper, no need to charge battery or top up the flosser container so can floss as long as i like.
easier to control the pressure using yr tap. it has a control on the flosser itself but i just set it to max so will just control the pressure direct from tap head. 1 hand on tap head, the other on flosser to direct it where to go. comes with 2 different type of head...1 for narrower sharper stream, the other for slightly wider.
