[Newbie] Building a new pc
enenyi
Considering that my plan is 200Mbps, what's the speed should i be expecting?
100-140Mbps. I'm on Singtel 200Mbps plan and that was the best I could get out of Aztech homeplugs. 50-70% efficiency for homeplugs. I've now switched out of homeplugs and gone direct LAN via trunking to my room to get full 200Mbps.
IceCreamPoop
144hz looks so tempting sia....my league of legends sometimes screen tear cus too much fps so sad......build wise just follow the standard grounding tips and u will be safe. I wish u great luck in your build.
P.S. Couldn't stop myself from commenting cus u are quite similar to the me back then XD.....plus we both 1997
DavidJohnson1997
After waiting for Amazon BF, Qoo10 coupons and Lazada 12/12 events, I managed to hoot all my parts at good prices and the deliveries were all pretty fast and satisfactory.
Completed Buy List
CPU+Mobo: Intel Core i5-6500 + MSI B150A GAMING PRO @ $484 (Fuwell)
RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 2400MHz @ $116.92 (Amazon)
GPU: MSI GTX 970 4GB GAMING @ $551 (VideoPro-Qoo10)
SSD: Samsung 850 EVO 250GB @ $104.26 (Amazon)
PSU: Superflower Leadex Platinum 92+ Full Modular 650W @ $148.72 (Lazada)
CASE: Fractal Design Arc Midi R2 - Window Edition Black @ $89 (Lazada)
OS: Microsoft Windows 8 Professional 64-bit Product Key [OEM] @ $28.30 (Reddit)
DSP: BenQ XL2411Z @ $363.60 (GamePro-Qoo10)
HS: Razer Kraken USB - Essential Surround Sound Gaming Headset @ $64.80 (GamePro-Qoo10)
Total: $1950
*All prices are listed in SGD and after discounts
DavidJohnson1997
So, I managed to assemble all the parts with only a screwdriver within 2 hours. Fortunately, I managed to boot my PC into the BIOS after a few tries as I initally forgot to plug in the cable for GPU.
Front
(I took out the HDD trays in the upper bracket and rotated it 90° for better airflow.)
Back
(Quite pleased with the cable management:s13:)
Window
Do give your comments and point out if anything is wrong.
DavidJohnson1997
Hi guys, a few weeks ago my computer started to auto-reboot itself after shutting down on its own when I'm playing Overwatch and GTA 5. Now, my computer will instantly auto-reboot itself when I load to the menu of Overwatch or when I click the 'GPU Stress Test' button on furmark.
I have already brought my PSU and GPU down for a check and it came out to be working fine. I have also ran the memory diagnostic test and prime95 without any problems. So I guess the issue lies with my motherboard?
DavidJohnson1997
MianBaoFren
ZrE0_Cha0s
could be your mobo faulty. have u tried with another gpu to test if it is slots issues?
btw is your specs is it accurate as your current system?
DavidJohnson1997
When I ran test such as Heaven 4.0 or Furmark the temperature will always be below 70°C.
I also suspect that its mobo faulty but thing is they only open on weekdays while i totally cant make it on weekdays.
What do you mean slots issues? I do not have another GPU to test.
Yes, my specs are still accurate
MianBaoFren
I think he meant by the pcie slot faulty. So if u could get another gpu which is working fine to test it out, it would narrow it down to that.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
