[NEWBIE] Need help for PC Spec
snowangels123
Hey guys, I'm new in this forum and would like to seek for some help for my PC. The processor, ram and motherboard are new, but the pc still running slow, I think maybe is the graphic card problem?
Here are my current spec:
CPU- Intel Core i5 7400 @3.00 GHZ Kaby Lake
Ram- 8.00 GB DDR4 Dual Channel @1066MHZ
Motherboard- MSI Z170A Gaming M7
Graphic card- 2017MB NVIDIA GeForce GTX750 Ti
Storage- 456 GB Wstern Digital
hellspawn_one
Need more detail as in what do you mean by "running slow"
Sent from LGE LG-H870DS using GAGT
gld998
ssd or mechanical drive?
Koenig168
You can run Task Manager to see what application is taking up the CPU and memory resources.
5star_pundit
use M-Flash to flash the latest BIOS
kracie17
i doubt there is such ram speed for ddr4. might want to check that out again and put to min 2133 or 2400mhz if your board allows you... 456gb WD, is it ssd or hdd? head to task manager, uncheck all unused software from starting up and see how it performs.. if still the same, slight chance it might be the hdd failure...
Audiology93
It is 1066mhz, if taken from CPU-Z because need to X2 which is 2133.
http://www.tomshardware.com/answers/id-2838092/2133mhz-ram-shows-1066-5mhz-cpu.html
Sent from HUAWEI MATE 10 using GAGT
singupingu
1066mhz is before dual channel speed. 1066 x 2 = 2132 (or 2133 for round up), means he is using 2133mhz ram
Sent from OnePlus ONEPLUS A3003 using GAGT
kracie17
snowangels123
Thanks for all of the reply and advise, I might proceed to changing the HDD and graphic card. Is there any recommend graphic card for my spec?
illumiRig
Agree with the rest, upgrading the hdd to ssd will really improve the boot time by a lot. Recently upgraded my 4th gen laptop to ssd and work as smooth as butter, faster than when I first bought it. As for the gpu if you intending to upgrade, gtx 1060 is worth looking at.
Hope this help. (:)
