Nintendo Switch 2
zensushi
Moderator
Moderator
Pokémon Legends: Z-A starting preorders today​
My pre-order was delivered today. 😸
evildoer
I check with you all...
i am now thinking of getting FINAL FANTASY TACTICS - The Ivalice Chronicles.. i am think should i get it on PC or switch ?
i am thinking to get on switch verison but the problem right now is.. i am still using switch oled / Lite when i am on mobile. i only switch 2 dock mode exclusively .. (Cause i really hate the extra weight on the switch 2)
Can i buy FFT Digital ... then buy the switch 2 upgrade .. instead of directly buying the switch 2 version.. this way i can enjoy on both system right ?
crystalnox
You can also buy the physical Switch 2 edition, it will work on the Switch 1 as well.
evildoer
Oic.. i thought all switch 2 game don't run on switch 1... if it has a "Edition" i will work on both generation ?
crystalnox
evildoer
crystalnox
oh i also bought fantasy life switch 2 (Digital) on launch.. does it work on switch 1 too ?
i really hope they will release switch 2 lite in 2027
Not for digital unless you bought the Switch 1 version + Upgrade Pack separately I believe.
evildoer
i bought the non switch 2 version for FFT .. since the upgrade is FOC
evildoer
may I check with you all if i buy Dragon Quest I & II HD-2D Remake switch 2 , will it work on the Switch ?
evildoer
No, the two versions are completely separate games. Square Enix thanks you for buying their game twice.
i am thinking should i get it on pc or switch 2.. if it doesn't work on switch 1 (i only use switch 2 exclusively in docked mode)
winningeleven
Hi. With 11.11 sale coming soon . May I know what is the "expected" best price deal for the Nintendo switch 2 promotion after using all the voucher ( shopee/Lazada)
Possible to get local mario kart switch 2 set $5XX?
Spectre007
back during 9.9 sale:
mario kart switch 2 + glass screen protector + cup holder = $543
mario kart switch 2 + 256gb card + official pouch = $628
will have same price again? 🤷‍♂️
winningeleven
Thank for your info.
For you. Which one u would choose ?
$543 or the $628
