No dry cabinet interm solution?
yusoffb01
dont use silica. doesnt work. you can buy hygrometer from daiso and test yourself
Ah_keong
I used drybox or airtight box with silica gel before I got the dry cabinet
alamakazim
actually for a while ok 1 lah
I say leave it in a sealed box with some food silica gel :)
dont need so panaroid
thedigitalmoments
Load up some Silica gels in the box. Be sure that the gels are still in the original colors. If the color changes to pink/ other color than normal, one should heat them up to remove the attracted mositure in them.
Regards,
TDM
dryteletubby
I own my sony a6000 and some lenses for almost 3 years. All the while I stored them in an air thigh box with silica gels. No fungus thus far...
EJB
This is only fungal protection. You have to protect the electronics & rubbers and lubrication as well.
alamakazim
everyone got their own set of mindset and experience...
anything reasonable is fine
for long term, dry cabinet
short term, dont worry about it... sealed box with silica is good enough
keenklee
In my experience.
For a dry cabinet, the humidity can be set easily. If the temperature is fairly consistent, the humidity will as well. The humidity can be set ideally to keep fungus away and yet not dry out the rubber, seals and lubricant.
For a dry box or air tight container using silica gel, setting the ideal humidity is a challenge and likely involves trial and error. Usually the humidity will be on the extreme low end which is detrimental to the rubber, seals and lubricant.
I also can say -
I have a camera & lens left in the open in the store room for more than 5 years. I just checked, no fungus.
I have another camera and lens left in a camera bag in office for more than 6 months. I checked, no fungus.
But I cannot say, what works will work for others.
P.S. I just found out that the emergency dry box I have, is leaking. :s13:
EJB
How does a dry cabinet help with protecting the lens that my getto solution does not?
Try and see, buy some expensive equipment and keep in both storage, see which one lasts and works better.
Nothing beats a practical test.
