No Sound after Restart PC
jimmy_sg
Hey Guys,
Just start using win 10 for 1 month.
Encounter a weird problem whereby there is sound when I boot up the pc but once I restart the pc the sound will be gone. Plug in and out the cable did not help, but strangely windows can detect the cable when i plug in and out... Reinstall the sound driver help, but once I restart the pc again, the sound is gone.
I found out that if I dun install the sound driver from the Asus support page and use the Windows default would driver. no such issue.
Any advise? Found it so weird.
Using asus-h370f.
Thanks so much!
Sent from Xiaomi REDMI NOTE 4 using GAGT
jimmy_sg
Yes. It's in the latest driver
ahwei91
If you don't need the extra features of asus drivers, can try the latest drivers 2.82 from realtek website...
hexenB
You can try other asus board's driver, as usually they tend to use the same chip, like H370I or Z370E (which has the latest driver - April)
H370F
Version 6.0.1.8339 2018/02/27 754.74 MBytes
Realtek Audio Drive
Realtek Audio Driver V6.0.1.8339
Updated Amplify Level behavior to prevent overwriting manual adjustments upon reboot or resume from sleep/hibernation.
H370I
Version 6.0.1.8339 2018/04/09 643.19 MBytes
Realtek Audio Driver V6.0.1.8339 for Windows Windows 10 64-bit---(WHQL).
Sonic Radar V3.6.26.48019 for Windows Windows 10 64-bit---(WHQL).
Sonic Studio V3.6.26.48019 for Windows Windows 10 64-bit---(WHQL).
Z370E
Version 6.0.1.8382 2018/04/12 645.24 MBytes
Realtek_Audio_Drive
Improve system stability & Support Windows 10 latest version (Build 16299)
Version 6.0.1.8339 2018/02/24 646.83 MBytes
https://www.asus.com/sg/Motherboards/ROG-STRIX-Z370-E-GAMING/HelpDesk_Download/
https://www.asus.com/sg/Motherboards/ROG-STRIX-H370-I-GAMING/HelpDesk_Download/
jimmy_sg
Yeah, I think if I am using Realtek driver, it's working correctly.
It is the driver that was downloaded from Asus that was problematic. Unless I dun want those extra features.
jimmy_sg
