Noise bleed from headset into Mic
queerquirks
Hi guys,
not sure whether this is the correct place to post this.
My problem is media/audio from my headset will bleed into my mic, which means my friends can hear what I am listening.
Using hyperx cloud 1 and onboard realtek audio, both headset and mic plugged front panel.
Any way to solve this? Thanks
fostdecile
Are you sure the bleed is from the mic? It could be that you have activated the "record sound from system" button somewhere. I dont remember where to get that option but i do remember that happening to me someine ago.
mcviechua
am using the HyperX Cloud 1 headset. No issues on this though. Not sure.. Can't help! ><
queerquirks
I dont rmb seeing such an option though in both sound options and realtek software, showing both disabled and disconnected devices.
Im not sure mine is headset or mobo onboard problem, either headset defect or onboard crosstalk. dammm.
Is your headset plugged into a usb or discrete sound card?
sglords
I think ur mic setting u need disable e playback from device
dexterlow
Hi,
I am using the hyperX cloud 1 too but using razer surrounds and razer comms when communicating with friends for dota.
No issue on this bleed noise ever since I used razer surround
sglords
Hi,
Please see the post thread date
