Note 2 battery
jacqn_lm
Hi i have a few questions here.. Wondering if my Note 2 battery is spoilt? as i have try several powerpoint but charging super slow. For eg 1hour only improve 10%. and its direct charging, i tried multi plugs, worse. And I need to off my phone when charging then the charging will be faster.
What is the min MAH of Powerbank should i buy for Note 2?
Thank you very much
Goondu
Thank you very much
It is most likely the cable that is giving the problem (the microusb pins, in fact). U should be able to buy the cable at S$10/-
Happened to my 2 x S3 (kids) and mine (N2). :D:D
jacqn_lm
Great! thanks i never thought it may be the cable issue. I have been trying to charge at various sockets too. Shall buy the cable to try. Thanks!;)
Skywalker87
Hi jac,
Yes i agree it is the cable issue. Try to get the authentic Samsung cable and try. You will be able to see a significant improvement on the charging time.
Normally, charging thru electrical socket is the fastest. Charging thru USB ports (with a good cable) is a bit slow but bearable but charging with through USB port with a bad cable, you can even find your Note2 batt discharging which charging which is really unacceptable.
jacqn_lm
Hi jac,
Hi Skywalker87,
Thanks for the answer! the cable i using is authentic.. maybe cable spoilt. Heard few friends also had same issues. I need to off the phone for some time and on it, then it will charge faster.
My friend told me to install the apps, Faster Charger to optimise the charging, doesnt work for my phone though.
