Note 2 dust problem
Slowx6
Im using note 2 titanium grey and i notice there's alot of dust stuck between the bezel and the screen. Any ppl have the same problem with me and whats the solution of removing it?
Rtcs08
hi
Philips screw #0 .
Unscrew 11 screws.
remove bezel cover,
Clean,
screw back.
for more DIY step by step.
search youtube for videos
or
iFixit: The free repair manual for tutorial
samson1
Just use a fine paint brush and brush out the dust occasionally. That is what I'm doing. Works pretty well. Don't need to remove bezel which is crazy.
