Note 2 short battery life span...
jq75
Is it worthwhile to buy a new battery to test or to adapt battery saving features?
Normal general usage, can last me only about a day only...
jq75
Bump for opinion
kyleongwl
Take out the battery frm phone and see if bloated. This can b tested by spinning the batt or a flat surface. Ifvit spins, bat is EOL.
sG_KYo
simple solution ... embrace Sony. :)
or welcome on board to Nokia 1520 ... battery life longer than all the samesung combined!
jq75
Guess will consider getting a new phone than new batt
benjicon
I had the same problem until yesterday, my battery was getting shorter and shorter life, but I fixed it.
I read that some people were experiencing this when they upgraded to android 4.3, one symptom I was experiencing was the area where the micro SD card was, was getting really really hot. So I did a Hard reset (start in recovery mode, wipe and reset) I rebooted and started fresh and the phone is fine now.
I was getting 3-4 hours of general use, after the reset, this morning, between 8am and 11am, (3 hours) I have only used 16% of my battery.
May be worth a try.
RequiemDK
Quick question: What is your kernel version?
The latest Android kernels seem to wakelock certain phones, causing Android OS to appear right at the top of battery usage charts. My Note 3 had phenomenal battery life at first, but after updating to the latest firmware, the thing only lasts me for a day now. Funnily, I turned on all the options - location reporting/history, wireless connections for location data, Google Now, etc. Didn't make a difference at all in the battery life. Weird as hell.
