where did you buy your note 20 ultra snap dragon from ?
how about warranty issue ?
did you get the 256gb or 512gb version ?
https://mobyshop.com.sg/phones/brands/samsung/samsung-galaxy-note-20-ultra-5g-snapdragon-512gb.html
thinking of buying this one
Agreed, the local set ROG 3 with 512gb storage and SD865+ costs $1540 at Street shops. Way more worthwhile than the SD N20U. Had both of these phones and the HKG SD N20U had some issues like no VOLTE for some local telco and also the Samsung pay points cannot be redeemed locally. Got the SD N20U 256gb at 1.8xk when it first came out.
You basically have a new phone? Change battery before... then change motherboard... then change OLED panel which will also trigger a battery change... like that do a one-to-one exchange save everyone a lot of work eh? This means you've been to the Samsung service centre 4 times? And which means you have to re-setup your phone 4 times? Samsung not very logical... do update us about the heating issue...Hi all! After not giving a **** after their engineer said no issues and 40deg is normal. I have been living with my n20u for a few months and saw there was a mark on the top.
Decided to go down to the service centre 1 more time last Wednesday... Guess what?
Engineer said the motherboard overheated and changed the MB! But didn't change the panel due to no stock. Now I am heading down to change the panel as the parts have arrived!
Yes in a way the phone's major parts have been changed.. 1 x MB, 1 x Panel and 2 x battery. 4 times in total to the service centre. 16 trips back and forth sending in and collecting it back.. setup 4 times.You basically have a new phone? Change battery before... then change motherboard... then change OLED panel which will also trigger a battery change... like that do a one-to-one exchange save everyone a lot of work eh? This means you've been to the Samsung service centre 4 times? And which means you have to re-setup your phone 4 times? Samsung not very logical... do update us about the heating issue...
I totally get what you mean but I have been a note 8 user all the way till note 10 plus till note 20. Not easy to make a drastic change when you are used to a certain UI and functions.. MB has been changed and I don't have the heat issue already. But what shocks me is that the engineer's level of troubleshooting and monitoring is atrocious.I think no point keep changing.the overheating and battery drain issues are caused by the Exynos 990, which is a lemon product by design. The problems will keep on persisting as long as the processor remains the same.
Best to sell the phone and upgrade to S21 series or change brand.
Maybe a new guy... not familiar with the system lar... haha... but yeah... 16 trips up and down is quite ridiculous... but glad that you have the phone working as it should now without the heating issues...I totally get what you mean but I have been a note 8 user all the way till note 10 plus till note 20. Not easy to make a drastic change when you are used to a certain UI and functions.. MB has been changed and I don't have the heat issue already. But what shocks me is that the engineer's level of troubleshooting and monitoring is atrocious.
Its their Exynos CPU that cost the problem, I used to be a Samsung note fan until I get both note 9 and 10 having the yellowish screen and heating issue, that the pissed-off problem on Samsung product which they cant fix on their software issue.I totally get what you mean but I have been a note 8 user all the way till note 10 plus till note 20. Not easy to make a drastic change when you are used to a certain UI and functions.. MB has been changed and I don't have the heat issue already. But what shocks me is that the engineer's level of troubleshooting and monitoring is atrocious.
