Note 3 battery draining only during overnight
kefen123
Hi just wanna ask if anyone can solve my phone problem, I bought my note 3 on October and recently (around 1 week) my battery started draining from 95% to 40%+ overnight but during normal day usage it didn't drain as much like as the night so I deleted some apps and off wifi and close every program that's running and also cleared my ram before I go to bed then after tat 2 days was fine as it didn't drain as much as previous but after two days the problem come back again draining from 90% to 9% from 11pm+ to morning 10am+ (without any usage).
So now you see the problem with my phone is it only drain overnight while I'm asleep but during the day it didn't drain that much. Hope someone can help me thanks.
Previously I downloaded GO launcher and GO keyboard and now I already uninstall them to see if those are the culprit
++ I using original s view cover and had around 29gb videos on my sd card so dunno izzit this that makes my battery drain like siao
andylyf
ghost ish playing with your phone in the night......
On a serious side. I thought Note 3 settings can see which app is eating up batt juice?
kefen123
Just wanna ask I'm using normal email but when I check the battery status it stated exchange services instead of email, my sis also uses same phone as me but hers is email and not exchange services
andylyf
both using same default email app ?
andylyf
then have to wait for experts to come in liao....
Windows Phone no such prob and my wifey Note 3 also no such issues... :D:D:D
SiaoAngMoh
Sounds like you set the email up using exchange. Exchange can be used for push email among a number of other things.
Either switch the settings in the exchange to fetch new mail manually, or remove the email settings completely, and re set it up using IMAP instead of exchange.
What email account are you setting up anyways, Gmail, Yahoo, or work?
kefen123
It's weird under the setting account my sis email is on Microsoft exchange activesync which is same as me but on the battery usage mine displayed as exchange services while my sis was displayed as email usage
Btw I'm using hotmail msn
twosix
Then why not you remove your current email account, reboot the phone, and set up the email account according to the same method as your sis? And turn off push email at night. Why the need when you're sleeping? Also, I will usually charge the phone at night and plug the power when awake in the morning. Why don't you charge the phone at night?
kefen123
Btw I switched from exchange services to imap email but my battery usage still stated 26% on exchange services (which is highest usage on my phone right now)
andylyf
got set to manual sync? Monitor it for a while and see if its the same.
Initial high usage might due to email doing the initial syncing..
