note 3: How to delete downloaded firmware?
cybernick
My note 3 automatically downloaded the Kitkat firmware, but I don't want to update it due to the SD-card write issues.
Is there a way to delete the firmware update or stop it from prompting me in the task bar?
cybernick
Anyone knows?
cybernick
Anyone knows?
walkingcorpse
go to the running process under applications, just clear the data and of the system update, cannot remember the actual name of the system update but it shld be still in the running process.
cybernick
I found a running application called "software update". Is it that?
How do I clear the data of the system update?
I only see a "stop" option. I stopped it & restarted my phone, but the software update still appeared again.
slacker
Go to setting->More->About device->Software update->[unchecked] auto update
gentoro
I already uncheck "auto update" for both my s4mini and s3. Awaiting it to stablise 1st.
cybernick
The auto update has already been unchecked. But I still get the prompt as the firmware has already been downloaded to my phone.
Anyway to delete it?
walkingcorpse
is your note3 rooted, if yes, the firmware should be stored in /cache, you can access it using es file explorer.
