Note 4 or Note 4 Edge..Which one??
tkc2263
Since both Note 4 and Note 4 Edge are similar in specs, which one will be preferred?
I am opting for the Edge as the curve is unique and will definitely gives a very different experience.
Having been a Note owner from 1 to 3 series, its time to have a differentiated device but still a Samsung phone.
Better still if it comes without a stylus, as I am not a user of the stylus.
What about you guys??
mokseng
The curved side is still very experimental to me. And definitely needs a lot of getting used to. I'm not the kind who would get it just because it's special, so I'd go for the note 4. Having said that, it's just my opinion as I'm not buying a new phone anytime soon. :)
Hello_Kitty
Of course the Edge. Note 4 is just an incremental upgrade, nothing spectacular.
seller4
You can always just leave the stylus alone and use the phone without it. That's the beauty of the Note series. It cater for both stylus and non stylus groups of users.
actan1
I think edge is quite interesting.
But I guess I will have hold the phone a bit differently unlike the conventional way we hold our s4 or note 3.
Probably lesser grip on the side.. hope won’t drop the phone so often. scarly the competitor comes out one with all the 4 sides with edge...
haha
Tan_Damian
Edge looks like it will edge out note 4, the signature side window is so exclusive.
uniquely_ad
quite an easy pick if you ask me,
Note 4 if you wanna play safe, Note edge if you wanna play experimental
zXioNGz
If you wanna Stand Out or be unique cannot go wrong with Edge, but I doubt it's useful lor, and think about Screen Protector, how to fit haha, only those soft Water applied then can
Jeremy1
Will Note Edge more prone to break if drop on the floor due to it's curve shape ? :s8:
