Same problem here. most can only get 7 to 10 mbps and i'm on 5Ghz connection with mobile data off.still cant resolved.
Can get 200Mbps easily with N4
Sent from GAGT Android App
Hi, I also having the same issue. Anyone managed to fix it? Send to services center helps?
which router are you using?
I cant remember the router model, but it doesn't matter. As long as I compare it with other phone.
Even my wife S4 gets better result!
S4 down/up: 25+Mbps/61+Mbps.
N4 down/up: 12+Mbps/90+Mbps.
Both using the same remote speed test server and the same router wifi 2.4ghz.
