note 5 wifi issue.
bigsnake
hi guyz,
i having this wifi issue as when login to my router with my note 5, it show connected but access to website after few minutes will disconnect intermittenly ..but wifi icon still show connected. any advise? thanks
renfred89
using Asus AC2400. Using my note 3 no problem at all
what u are experiencing with ac87u is just as common as what others are experiencing. do update to the latest firmware released yesterday for ac87u.
nothing is wrong with note 5.
jnashville
I am using ac87u too. Wifi on note 5 will be connected but cant surf the net. After i update to the latest firmware, the issue seems to be gone. Hopefully its a permanent fix.
ruffruff
Same issue with me. Connection is intermittent on 5ghz AC band. But no issues if on 2.4ghz band
bigsnake
after upgrade firmware on my router.. the issue came back again.. :(.. sianz liao!
StanII
on Aztech 7009AC, also issue with my 5Ghz wifi, not stable, shows connected but no network connection and not to mention huge battery drain on 5ghz wifi overnight.
