Greetings all! I would like to acquire a NAS but I have this puzzling question about hot swap.
If I run any kind of RAID(not including RAID 0) and I did a hot swap, will it be considered that the HDD that I swapped out has failed and data will be re-constructed into the new HDD that I plug in?
If I do not run any RAID, I do a swap, I will not be able to access whatever files in the HDD that I swapped out but I can access the files on the new HDD that I had swapped in right or does hot swap has to go with RAID?
Assuming that the NAS supports hot swapping.
