nucleus connect ONT killed second power adapter so far
wwenze
First time it died, my internet slowly became unstable, power to the ONT was on but keeps resetting the moment it connects
Second time it died, my internet became unstable very quickly and the router complained cable disconnected, when I went to the ONT the power was off
Looks like 12V 1A isn't enough for this?
royfrosty
ONT power adapter if really faulty ask Starhub to replace it for you. It is also good to check the RJ45 cable from the ONT to the Router WAN.
RJ45 cable from the router to the switch (Assuming) you have one is also a good idea.
tsteo77
If the power adapter can't supply enough juice, the ONT won't power up. So somewhere is faulty, can be
home wiring or the ONT.
watzup_ken
I suggest you try plugging the power adapter into another socket/ power point to try out. Sometimes a faulty electric socket may kill the adapter over time. The Nucleus Connect ONT that came with the Starhub broadband is not even warm under load when I touch it, so I don't think it is drawing too much power. Otherwise, it should at least heat up quite a bit.
watzup_ken
I don't think it won't power up since it should not be off the power requirement by much. So if the ONT draws too much power, I do expect symptoms like the adapter running very hot since it is overworking. But I do agree that it could be either faulty power socket or ONT. But will need to isolate the issue. The easiest is proably to test the power socket by changing to another power point/ extension for now.
86technie
If using extension, opt to buy one of this socket tester to test if any socket have issues.
407e2f26e3eb308b304c7a8ab648413d
Can be brought from any electronic store or self fix.
