Darkzi0n
- Oct 2, 2010
Im a girl! i tried to apply for sow but doubt I'll got in since it's rather packed! i need help regarding bidding! are the core modules preallocated or i have to bid? and do you have any easy gem or ss modules to recommend me to take?? Haha. and i heard that stats is really competitive?!
stats does not preallocate any module to u, so u have to plan and bid everything urself, my advice is have a balanced mixture of module every sem.. maybe 3 core, 1 unrestricted elective and 1 fac/uni requirement per sem. (u can visit my blog to have a rough idea as i listed wat are the mod i took for my first 2 sems)
like wat Rusty89 had said, ec1301 is one of the must take if u have econs background, as it is mostly a revision of JC econs and it will help to satisfy one of the breadth req. there are also alot of other GEK/GEM for u to choose, and there are bound to be some that will interest you. i personally think that choosing a mod based on ur interest is much better than choosing a mod bcos other ppl think it is easy. ss wise, there is a mod called sss1207, which is the onli ss that has MCQ that i know of and it is also one of the few offered by sci.. so u might be interested in it, esp if ur language is not good. however sss1207 is onli offered during sem2.
Steep bell curve meaning? actually i have been through cors talks by prof and the cors slides on the web, but i still feel that i know nothing about it.. would like to know if for each round, how many times can you bid? if its more than once, then won't your bid get beaten as the day goes by? ec1301 as gem is it?
steep bell curve means that if u scored 98/100 for the module.. but everyone else scored 99 and above, u will still be given a very low grade. basically the bell curve is something like a normal curve.. eg. top 25% of the students will get A- and above, the next 50% will get btw B- and B+ etc etc.. so if the module is very easy, then the score needed to get an A will be skewed to the left (skewed left means bulk of the curve is on the right), and hence it will be called a steep bell curve. such mod can be bad bcos any careless mistakes can be fatal for ur grades.
for the biding, u can bid as many times as u wan before the bidding round is over..and no, u wont get beaten as the days goes by unless alot of ppl is bidding for very limited slots which i dun think it will happen for ur first sem.
