NVMe Speed question.
veltix
Any brands of ssd will run at read speed of 7300, 7400 up to 7500 rpm. It just only brand. Right? Unless durability last longer than others.
tsteo77
SSD are static storage, only HDD has moving parts that spin at a speed of 5400, 7200 and 10000 rpm. :)
86technie
Sorry its mb/s
So any brand of ssd with the mb/s of 7300 up till 7500 mbs will work. Just different branding. Nothing special like A last 5 yrs longer than B, or A is thrice as fast B.
Get reputable brand like Samsung, WD etc. which have better endurance than other brands.
Speed wise it really depends what you are doing.
Like surfing internet Chome won't hit 7300, only heavy file transfer, editing etc.
Than higher speed NVME speed will benefit if not typical NVME whether PCIE Gen 3/4
with up to 3500MB/S will do fine for all usage.
FYI lower NVME speed doesn't mean it is slow.
Phen8210
PCIe Gen 3 is fast enough no matter what you do. The most important is how long it lasts. Some have TBW written with huge numbers but fail over and over. I personally go with WD, Samsung, or Crucial (proprietary).
ragnarok95
Senior Moderator
Senior Moderator
Crucial T500, Seagate Firecuda 520, WD 850X. SK P41.
Will avoid the S.A.m. for me. No thanks.
kappak
PCIE 3.0 > 3500Mbps max
PCIE 4.0 > 7500Mbps max
PCIE 5.0 > 10000Mbps++
no diff in daily task except huge file transfer provided both end are 7500Mbps speed.
rest depend on how deep pocket you are.
Famous SSD : WD SN850X/Lexar NM790...etc
Save money SSD : Crucial p3 for pcie3.0/p3 plus/p5 for pcie4.0
KYZT2021
speed useful if you transferring lots of stuff e.g video editing
