Nzxt kraken aio users
raysusan
Is there a way I can store the setting when ever I restart pc?
I am on the latest 3.5.10
hlots123
frm wat they posted, seems like its deleted on boot & re-created when u tune or make changes to settings...
did u look before or after making a settings change?
hlots123
looked at cam forum, most not happy with new ver & cam overall :(
nzxt & cam are separate co?
Psycovirus
The new CAM, ver 3.5+ is really light on the resources. Fast boot up too. I did not have any issue of not saving settings when PC restarts.
Previous CAM, the settings could be lost when PC is force restarted.
I saw on their forum,
Post by Mod
Eric Lam (Admin, CAM )
Hi there, please go inside this directory and delete the CAMSettings.sqlite file
C:\Program Files (x86)\NZXT\CAM\CAMSettings.sqlite
then try to restart CAM and see if that works.
LiLAsN
Post by Mod
Agreed with you. This time, when re-installing the software, it will automatically re-download my fan curves and custom light options automatically. No need for me to redo everything.
Similarly, when I shut down my PC instead of my usual Hibernate, I will just leave the software running while open for 1-2 mins and the missing Kraken X62s will reappear along with my custom settings.
Note: I have 1 Hue+ and 2 Kraken X62s with 2 different fan curves and custom light options.
Though at times, the app can only detect 1 of the Krakens which requires me to close the software and re-launch to make sure it detects both.
raysusan
Post by Mod
It don't work
I reinstall the earlier version it works! But can can't regonise my cpu and temp......walan
