Got the homey and full set of MCO switches from automate asia. Looking forward once my reno is finished
homey is not cheap..those switches is even more crazy price...u google will knowwhat much did u spend on the switches?
wire it your self? Neutral pts is available for PowerPoint switch..tap it from your nearest powerpoint..I bought a 4way wifi smart switch which requires Neutral wiring. But realized my house light switch wiring didn't have Neutral routed.
Anyway to still make it work? Without getting electrician to wire a Neutral wire down to the switch?
power point already have neutral...if your switch is next to power point..its easier to tap the neutral wire from the power point...if the switch alone..then need to tap from db box or the wiring trunking..if not rewiring whole house possible to add neutral wire to all power points and switch?
Would there be any issue if there are devices powered by the power points and hence the outgoing neutral wiring is somewhat "live"? And we are also hopping this neutral wire into another smart switch, will the smart switch malfunction?power point already have neutral...if your switch is next to power point..its easier to tap the neutral wire from the power point...if the switch alone..then need to tap from db box or the wiring trunking..
Sent from Samsung Note 10 + using GAGT
neutral is neutral..they dont connect to live...this is what I understand from the electrician..Would there be any issue if there are devices powered by the power points and hence the outgoing neutral wiring is somewhat "live"? And we are also hopping this neutral wire into another smart switch, will the smart switch malfunction?
Why everyone going with such ghetto solutions for aircon control when there is a reasonably priced IR controller: https://www.amazon.com/gp/product/B07FZK8NP2/ref=ox_sc_act_title_1?smid=A22JB4IX6UIIZL&psc=1
I use ambi climate.... haha
Heng I use Sensibo since 2016...
Anyone manage to use a motion detector to turn on/off bathroom lights via livolo switch?
I was told it’s not possible to do it as there’s no “feedback” from the switch?
Hi! Dipping my toe on home automation. I bought a mi smart hub and aqara switch. But I’m struggling. Because seem like mi hub need to singapore server and I don’t see aqara switch. If I change to Chinese server I cannot see my mj smart hub. Only have Aqara hub. Did I buy the wrong hub?
ambi have AI...but AI can screw up sometimes..isnt the link somethings similar to sensibo? actually, they works the same rites?
keeps seeing this sensibo ad in fb
nb tryings to make moi spends![]()
