wacko
possible, just tap on the powerpoint switch beside it,
don't anyhow advise, the powerpoint is likely on a different breaker circuit from the light point, so cannot just tap the powerpoint neutral for the lighting switch.
Alphas
Is this true? Since residential electrical is only single phase, I am under the impression that the neutral is common be in the lightings or power point circuits. Furthermore, the circuit breakers are always wired to the live wire, never the neutral wire.
Aftathott
would like to ask regarding Smart dimmer switch options.
Intend to have Sol Luminaire lights integrated with smart dimming options on the wall switch and also a wireless switch to power it on.
Currently exploring Aqara, I see that there is a H1 Rotary switch on taobao, not sure if I can integrate it with the lights to incorporate dimming + another wireless switch at a different location to turn on/off.
Tried googling but not much information on the Aqara H1 wall switch rotary dimmers, I understand the wireless one only works with Aqara lights.
batniss
i think you don't know HDB electrical to say that i am advising anyhow.
batniss
Not all comments are from real substance. learn to differentiate from the real ones.
Evilbear
The knob can only adjust devices with % values in the aqara app like their smart bulbs, curtains or blinds.
quarkz
Alphas
I am aware of the residential electric wirings and this is the reason I questioned his (wacko) statement. Many of the smart switches operate with an internal relay, which close the external circuit on live wire to the device. The neutral wire to the smart switch is ONLY to power the internal electronics and relay, not the device itself.
wacko
there can be multiple RCCBs, so the advice is not prudent.
wacko
I wouldn't assume that the OP is asking in the context of HDB only. but if you do want to substantiate your advice to be applicable only in the context of HDB electrical wiring, then that would be good.
batniss
Yawn.
Can tell some people is trying to wiggle his way out with his limited knowledge
Alphas
Is anyone into Zigbee integration on Home assistant? I have a Tuya ZIgbee 3.0 gateway and wanted to add the gateway into Homeassistant. The Zigbee gateway can be added in the Tuya app, however, the ZIgbee gateway cannot be integrated (not detected) on home assistant loaded on my Raspberrry Pi. So I am consolidating all the smart devices into a single ecosystem rather than having multiple app for different brands of smart devices.
duran
I am using Sonoff ZigBee 3.0 USB stick with HA on RPi4 with the Zigbee2Mqtt integration. I have Ikea, Tuya, Aqara and Sonoff ZigBee devices working with Z-wave and WIFI devices in my local network on single HA app.
Shadowlite
You'll only be able to see it through the Tuya integration. This is because the Tuya gateway is a WiFi device (i.e. it connects to Tuya's cloud servers), thus you can't integrate it directly into HA. Tuya has announced native integration (including local access) into Home Assistant, but as of now local access has not been implemented yet.
As such, I stopped using the gateway and used the Sonoff Zigbee USB dongle similar to @duran.
Alphas
Is Sonoff ZigBee 3.0 USB stick coverage good, is the zigbee signal stable?
I see that Sonoff released a newer variant of the ZIgbee 3.0 USD stick, are you using this?
https://www.lazada.sg/products/itea...-network-range-i2089190309-s11597813233.html?
Does this means the Tuya Zigbee gateway is useless in HA? There have been quite a number of updates on the Tuya v2 integration and local tuya, wondering if they could be able to support the integration of their gateway in HA?
There is a method to add Tuya ZIgbee gateway in HA describe in this article, maybe it can work.
https://zigbee.blakadder.com/Tuya_TYGWZ-01.html
Shadowlite
Don't think it's totally useless, you would be able to see the zigbee devices added via the gateway in HA. But not sure about the level of support (i.e. whether all zigbee devices are supported, as I only added 3 Zigbee devices via the gateway before I switched.)
Just that all controls will be via the cloud api though the Tuya HA Integration, and you have to add new zigbee devices via the app.
Saw the article, I didn't try as I didn't have the same model. For the official integration, I read that their focus now is on device support rather than local access, so not sure when it'll be ready.
I'm using the sonoff USB Dongle plus, it's pretty good for the price, bought extra to flash them to use as zigbee routers also. Would recommend to update to the latest firmware version as it'll improve stability.
duran
I use it in a HDB environment and the coordinator in one bedroom works consistently with a scene switch that is at another corner of the house. YMMV as it depends on many factors like walls and interference with other 2.4Ghz devices.
Yes, I am using that Sonoff ZigBee 3.0 USB stick. I also use an USB extension cable to keep some distance between the ZigBee antenna and the RPi4's built-in antenna and metallic casing.
I also have Tuya WIFI devices that are using TuyaV2 integration on HA. So far, TuyaV2 is still very much WIP and simple things like switch status did not update properly until a few months ago. Waiting to see if the development would speed up with the official integration.
wira
hi all
am starting my reno soon and will be planning to set up a simple automation
My requirement is simply :
1. use smart switches and able to control all lights via app and setup automation via google home, ie can ask google to switch off all lights or on/off specific room lights
2. Use motion sensors to turn on/off lights
3. control ceiling fans via app and google home
4. Control aircons via IR blaster
5. Control curtains using Switchbot
What would the experts here recommend ?
Would it work if i use Aqara switches, motion sensors and Aqara Hub ?
A friend also recommended to use Tuya instead. any comments ?
Also do i need to place a hub at each floor/ room ?
