Hello all! Thanks for the many good tips and suggestions here, I found them super useful to get started on my "smartifying" my home
I recently installed a couple of Aqara D1 Switches (paired to Xiaomi gateway 3) for my ceiling fans which can also be controlled via a remote control. I noticed a number of issues which I was hoping to hear views on.
1. Random switching off of switches, which seems to be a common problem based on searches online. I've tried the suggested solution like loosening the screws, but the issue persists. Might anyone have any ideas how to troubleshoot this?
2. Switch Log shows that a "Click" may not necessarily match a "On" or "Off", or vice versa. Is this normal?
3. When I control the fan with the remote (e.g. change blade direction), the switch lights fade away, before making a beep sound about 1 second later to indicate that the switch is turned off. This occurs pretty consistently, so I was wondering if anyone has encountered this too. My current "workaround" is to turn the switch back on after it goes through the above after each time I use the remote, but obviously this is less than ideal.
Thanks in advance to all; any ideas would be sincerely appreciated!!
