merriman
For smart switches, technically all just neutral. The electrician still need to physically tap 1 (as default) of the switch to each of the light and fan right & use app to configure how & when to on-off. Remaining extra gang/switch can customise what to do (e.g. kill switch)
Yes. 1 output of normal switch will require 1 output of smart switch. Just a mirror of the normal switch.
As for extra gang of the smart switch to be able to be programmed(aka scene switch) , really depends on the switch. The switch has to support some sort of decoupled mode in order to do so
For smart switches, noted the Aqara Z1 Pro is popular choice here. Any particular reason? Saw Prolink launch a series of smart switches and sensor and price more friendly. Any once using it?
https://sg.shp.ee/nz3NnxZT
Depends on what platform you ultimately plan to use
for appliance like fan and aircon it can be smart. Is there any need for light to be smart? Unless I want it to be adjustable RGB?
Change brightness? If you only need to on/off the particular light, then don't have to get smart light. Just normal light connected to a smart switch
RyanJ
Currently in the midst of reno, will be doing neutral wiring.
Tentatively planning to use Sonoff Matter light switches, but they lack their own 20A switch for heaters.
M5M_1600_01.avif
I will probably get their NSPanel Pro as HA display and controller which acts doubles up as a zigbee hub.
NSPanel-Pro-120_1600x1600-10.avif
Question is - Can I use other Matter compatible 20A smart switches and it will still be integrated and controllable from Google Home Assistant interface ?
I prefer no additional physical hubs if possible and I hope not to use vendor apps
taquito
Anyone using Xiaodu X10 or X11 Ultra? Does it work in SG? Need an AI companion device for my dementia mother..
kun1he2
Mine is MSXY-FN10VE.
Just inform your model to seller to verify compatibility. The HA version is cheaper.
I installed it myself. I believe you can request for installation.
How's the spacemate?
Noted that you got the Tuya version, how's the response speed?
Not sure if you're using Tuya Local on Home Assistant - curious to know if it works.
Mecisteus
Working very well so far.
I connect to my smartlife. I don't have HA.
Response is within milliseconds. Fast enough to me.
Mecisteus
Currently I have about 20 Smatrul touch switches. Already used 5 for like 1-2 months.
Will report here if they break down.
So far the wifi one is nearly flawless. The zigbee ones are about 97% uptime. Probably due to the hub which hangup about 3% of the times.
Just to review.
I have some switches used for 1+ year now and many more for 9 months.
I'm quite happy with everything.
So far, only 1x switch was faulty after 7 months. Smatrul sent me a replacement.
Mecisteus
Is there options to choose from? If there is, I would have chose the deepest one. Current standard ones just too squeezy for smart relays with normal switch.
Looks like there are up to 49mm depth.
kun1he2
Just thought I'll post a quick update on the spacemate wifi module for starmex ac:
https://spacemate.sg/product/wifi-module-for-mitsubishi-airconditioner/
I have the Home Assistant version, which unofficially supports Matter over WiFi.
Tested able to pair and control directly with Apple HomeKit and Google Home ecosystems via Matter although not officially supported yet.
Also tested working well with Home Assistant via MQTT integration.
If you're the DIY sort, you can also try building your own via ESPHome - which I did.
Hit sluggish control issues with official project:
https://esphome.io/components/climate/mitsubishi_cn105
Switched to using this project instead and it is rock solid so far:
https://github.com/echavet/MitsubishiCN105Esphome
To expose the devices via Matter to other ecosystems, check out Matterbridge.
If you're already using Home Assistant, this works well:
https://github.com/Luligu/matterbridge-home-assistant-addon/blob/main/DOCS.md
So... anyone wants to buy my spacemate unit described above which is still currently installed in one of my units?
Do pm me if interested.
Mecisteus
I would have bought from you if the Tuya version.
kun1he2
Do you use the SmartLife app to control your devices?
Or mainly using Google Home or Amazon Alexa especially for voice control via Tuya cloud?
No plans to start on Home Assistant yet?
I started with purely Tuya too until I decided to integrate with the Apple Homekit ecosystem since whole family on Apple iPhone and Watch.
It glues everything together - fun project with lots of possibilities.
Mecisteus
Yeah just simple setup with smartlife app and mobile phone only.
No touch panel, no home, no Alexa, no HTA. ☺️
I don't really want the extras and fun.
sky00sky
Unifi /smart home u get seperate team to do setup, installation and what not.
Cos electrician unable to do the turn key service bah...pull wire still okay
RyanJ
I contacted Unifi Sg and also got the Unifi store staff to "vet through" the equipments / POE power requirements / wiring diagram.
But if still cannot get it up, I was given a Unifi "expert" that I can contact to ask for assistance ( for a fee .. )
See how.
duhduhduh
Is Broadcom rm4 pro still the best to control non smart fanco rito fans and Mitsubishi air cons?
Is one RM4 pro sufficient for standard bto 4 room flat?
kun1he2
I’m using the RM4 Pro to control Fanco fans via RF in 3 rooms, no issues.
Was still new to smart home back then which was 6 years ago.
If I were to redo the RF control part, I’ll probably look at Tuya ecosystem options.
For Mitsubishi Aircon control, read the earlier posts, best to avoid using IR to control.
