Update on my Aqara Non Neutral 2 gang that simply just died. Performed a post mortem. No physical burnt marks. However, a possible leak from the looks of it?
The first unit that failed or new 2nd unit failed?
Any idea how to voice control Broadlink RF light switches via Google Home ?
I can voice control their Broadlink smart plug, but the RF light switch cannot, even when i set as scene in IHC
anybody got inexpensive solution for automate curtains?
Share link brand reviews ...Not sure if this helps, but I paid $190 for 3 motors from Lazada and $400 for 3 tubes of Korean blinds from Carousell for my 5 room living room windows.
Seems like switches got high failure rate without neutral. Probably u can consider inline controller?Hi All, can someone recommend a wifi/smart switch to replace analog 20A water heater switch?
I would like to control the water heater switch via Google assistant.
Thanks in advance.
https://www.lazada.sg/products/sonoff-basic-wifi-smart-switch-i221414040-s337263732.html
Not trying to promote this vendor but search yourself for alternative, there are cheaper ones.
I saw some reviews that there are safety concerns for sonoff... any views on this?
not sure about others. been using it. so far so good.
Water heater and oven switch need 20A, I read the sonoff is 10a, still feasible?
How u use them? Behind ur wall switches?
