[Official mITX Build Discussion Thread]
Op_Valkyrie
Two OS In 1 Display
1 Keyboard & Mouse
Using hypervisor type-2?
Pretty neat stuffs...
mnemo_05
direct die cooling, too much risk imo
but then again, the temp gains will be something! let us know if you went ahead with it, I had mine delidded and used CLU. dropped my temps by an average of 17c. I wonder how well a direct cooling will compare
Op_Valkyrie
Monitor support two input, connected to my PC and MacBook Pro.
I using symless server and client based application for mouse and keyboard.
I thought u running hypervisor... I just saw a thin faint line on your monitor that separate the OSs...
Op_Valkyrie
Will do bro... 17deg is quite a lot IMO... nice one
Encrypted11
Guess hand tighten than machine tighten the cpu block thumbscrew :s34:
Its mobo dependent, but very likely the standard asetek AIO backplate will have some play/not tight with wriggle space. (googling common corsair AIO model, nzxt, evga clc etc + backplate loose all yield similar discussion)
Sho don't mistaken that its too lose and keep tightening, cause its an "asetek expected behaviour thing". For me (cuz there's IHS) I just push the block against the mobo after tighten thumbscrew before closing case window in case there's more than expected "sag".
TrueBeliever_jh
wow nice. I was thinking of getting a HDMI KVM before but problematic I feel.
I wonder does it work with 1 display + HDMI switch or not.
wkweksl
Good thread with nice stuff.
My 2 year old rig just transplanted from a Node 304. Waiting for Asrock ITX AM4 offerings.
CPU | Xeon E3 1231v3
Mobo | Asus H97i Plus
GPU | EVGA GTX1060SC
Memory | G.Skill F31600C9 (8GBx2)
Storage | Samsung 850 EVO 256GB
Case | Fractal Design Nano S
PSU | Silverstone SFX600 80+Gold
CPU Cooler | Corsair H60 + Gentle Typhoon AP15
Bottom Intake fan: Gentle Typhoon AP15
Front Intake fan: 2 x SP140L stock from Corsair H115i
Op_Valkyrie
Not all monitors can do split screen on two sources rite? I saw some is pic in pic like tv kind...
Op_Valkyrie
Thanks for support! :)
TrueBeliever_jh
yeah. appears so.
my dream got dashed again :sad:
my dream setup would be shared keyboard + Mouse + 1 display.
then use shortcut to switch display.
the software KVM works more liked having the displays side by side.
guess KVM really is the solution for me.
VeeLee
Mine monitor is Samsung CF791, Support Two Display Input.
I am seeing the monitor industry moving towards two display input.
Dell and Philips have 1 model with this feature and got higher end monitor with Quad Screen.
I seen fuwell selling this.
http://www.philips.com.sg/c-p/BDM4350UC_69/brilliance-4k-ultra-hd-lcd-display
Nice. Is it laggy compared to hardware KVM?
https://symless.com/synergy, mine PC on LAN while my Mac is on Wifi.
Surprisingly it's really very smooth and symless.
Problem with Hardware KVM introduce a lot of cables, unless you are in a secured environment, software KM is better.
Yup not all at this moment.
mnemo_05
waiting for some awesome Ryzen ITX builds
the Asrock X370 Gaming ITX/AC looks really nice.. Asrock has been releasing good looking boards lately
