Oneplus 7!
kashix
You're running the Android Q beta 4? How's it? Stable enough to run as daily driver? Thanks! I was wondering if I should upgrade to Android Q beta hahaha.
Sent from Google PIXEL 3A using GAGT
braveheart7172
Just bought a OP7 Pro from 131Express on Quube. After 15% Amex, it's costs me $746. Damn happy. Its cheaper to buy from Quube than to use $120 voucher and Amex combo to buy from Qoo10 by the way.
jtec14
When did you buy your qcoins using amex? at 1.4/qcoin or 1.38/qcoin?
It may be due to the drop in Qcoins value, just dropped to 1.38, earlier was 1.4.
Now you spend less buying qcoins and using it in Quube but if using it to pay in Qoo10, you need to use more qcoins.
jtec14
so far, op7 is on par with xr smoothness after a week of usage and haven't really experience any lag that makes me want to pull out my hair yet lol :o hope it stays tihs way even after a year or 2. i know this phone isn't that ex to expect so much, but 8gb rams is really amazing coz my laptop only 4gb rams whahahahah
If the quality is the same as 5T, I think your hair are safe.:D
I used 3T > 1yr and 5T coming to 2 yrs, i haven't noticed any lags.
btw found any good cases and full adhesive tempered glass already?
Have a budget, I am waiting for good price point to buy non pro also.
WhiteAnt
Nice to hear that your op phones still not lagging! High chance it won't lag for current standards then since they packed in so much rams and storage that it's so scarily fast
I will be using the preapplied plastic sp, I'm fine without tempered glass as I don't wish to add on further weight to this slim device. Looking at spigen case but not in a hurry as it will bog down the weight too :(
If you're not in a hurry can wait for price to drop :o not sure how much it can drop further, maybe 500?
mahcosg
i check out the oneplus 7 and realised it doesnt have ultra-wide lenses which is a great turn off for me.
-Grift-
Been using the rugged armour for my 7 pro and coming from my iPhone 8 Plus with Spigen slim armour the rugged amour is very nice and slimmer than the "slim" armour design
braveheart7172
I bought when the Qcoins are 1.38. You are right - it will need more Qcoins when buying from Qooo10
Aikon
Anybody with blue Oneplus 7 pro notice the blue paint around the camera rim coming off? It's a bit unsightly. Had a case on it since day one.
kashix
OnePlus quality has always been like this. My last few OnePlus phones also like that. Paint drop and the camera rim. Sometimes out of box already like that.
KeYoKe
Yes i must say this too. Tbh even if u take ur phone in and out of case will notice scratches at the side of the phone
Their qc is nt as good as others
kashix
That time I buy from newstar, almost every set I see also got defect. Have to settle for the set with the least cosmetic defect. A bit contradicting. Cause their motto is "never settle". Haha I think you also Kenna before right
gerald27
Use Supcase unicorn bettle :s12:
I saw the video on this case for OnePlus 7 ... apparently the case and the camera are flushed, which means no/very little protection on the camera bump :s22:
I bought Ringke in the end for my red phone :o
anthonygreenisreal
Coming from an iPhone XR and the Pixel,the vibration on the OP7 is incredibly weak even at the highest setting. I missed a few phone calls due to that.
