OnePlus phone goot a not?
Jian19
s25 ultra now 1148 with vouchers
oneplus 13 lowest i saw is 719 but heard oneplus also got green line issue
poco branding is just global rom version of xiaomi
realme usually cheap and good specs but mediocre camera that's why can afford to be cheap
That's OnePlus 13r
OnePlus 13 standard around 1k
sacredrays
pushtopen
if you don't mind being guinea pig for awesome experimental features that sometimes don't work out in exchange for a cheaper phone with flagship killer specs
then yes, it's good
if want tried and tested then probably safer to go for other brands
green line should be solved since OnePlus 12 according to jerryrigeverything after opening up the phone, he noted that the cable connecting to the screen is angled differently with less flex/stress as compared to previous models which had the lines
SpawnXp
mister mobile change 1 screen only $150 +/-
i lost my trust with them. that time go replace my screen. i choose the grade b one which states might have green line or patches, to me which is ok because is a spare phone.
but after change already, they tell me oh cause grade b, Spen cannot work anymore.
i was like wtf. i use my spare phone cause of the spen for note taking.
Jian19
It's grade b for a reason 🫡
nonameless
OnePlus use China company Boe screen now I think, no more Samsung. News is op15 coming with 8elite2 n minimum 7000mah new type battery used in 13.
masashi
Using OnePlus 13R for months and it has been great 👍 everything works well and can handle games at high resolution
born2fly
I own 2 OnePlus phone I most say there are amazing same par with high end Samsung phone but 30 cheaper
