- Sep 16, 2018
Think the most concern of using it would be the CPU,memory,disk space usage for Adguard home, if we are talking about running it on the router itself.
Currently CPU and meme usage are fine. Disk space usage is the no. 1 issue which can be overcomes by using extroot with a USB stick attached to router. Also set logs to minimal. I had tried extroot once but removed it since I'll be using the USB port for something else.
On what device specifically do you run pi-hole on?
My OpenWRT is running as a VM on an Intel J4105 Mini PC with Proxmox Virtual Environment (PVE). Then I have two Pi-hole LXC containers running on PVE as well, one for OpenWRT and the other for my Asus RT-AX86U. Take note I have two independant home networks.
But sometimes I will switch OpenWRT to pfSense and then only one Pi-hole LXC container will run in that case. I use pfBlockerNG with pfSense.
