Openwrt Router Firmware
sgcarousell
I see. I have no intention to install Windows 11 VM. That one needs quite some resources. So in your use case, it is indeed better to use Intel Core i3-N305 compared to Intel N100. I assume you will need 16GB RAM and 1TB SSD storage? Will you add external HDD/SSD using RAID 1 (not so sure if the Beelink support this feature)?
I use Google ONE for photo backup (200GB tier at S$40 per year, but may need to pay S$140 per year for the 2TB tier down the road, say in 2026 or 2027). I figured it is much easier to use Google ONE compared to use a local NAS.
I have Singtel TV and some paid online streaming services. I do not need to have local storage for streaming.
Then I have a simple OpenMediaMault file server running on a Raspberry Pi 400 with 512GB USB SSD for temporary file sharing and backup. This one is usually OFF and only ON once per month. Then I use two USB HDDs as well for documentation backup (very little stuff to backup in reality so probably once every month)
not planning to do raid, but going to install a 4TB sata, to expand the default 512 which come with the system, i prefer to have my data store locally n not in the cloud. It is not a back up really, just a duplicate of whatever i have on my laptop n handphone, in case i lost the phone, the photos wont be lost too.
TanKianW
I think a storage server or NAS of some kind (with RAID) should be a better fit for your use case.
A duplicate which is not a backup has no point for duplication in the first place. In fact, you are setting up another backup with duplication. Or you are trying to say the data is "not critical"? Personally, I will think photos of memory, both good or bad, should be critical data.
And to rely on just local storage as backup, and not in the cloud is a recipe for disaster. Unless you know what you are doing, or at least "storage savvy" enough to have multiple back-ups.​
BradenHeat
interesting stuff , took the plunge and gotten the slate AX for my travel needs,
currently with [ travel mate/ sqm_qos / nano/ ]
will be keeping an eye on this thread for recomendations,
4x4 wifi 6, with openwrt, im just wondering whats making it hard to convert the existing asus platforms,
asusmerlin might be that good, but openwrt support, from just merely playing with Gl-Inet , via LuCI seems to have way better advantages
@xiaofan
now i know why you're stuck with older hardware, some specifics, with deliberation
amazing, the slate AX is only as big as a middle size gaming mouse,
tried, with amazing results ,
- plugging type c from my Laptop and even my iPad,and the little fella ran ,
- wireless tap the wifi in office and outside, no issues [ might be due to travelmate , configuration ]
i wont be joking, if i say this, but my recommendation for asusmerlin supported routers might just change to ,
gl-inet ax wifi as main router/ -Adguard home
to
any other wifi 6 routers [ as access points ]
checking the ARM processor, and it barely being trottled,
its really a long way coming,
hm
Slate 2 wifi [ in type HDB fiber store room ] ---> to wall --> to 02 x old singtel./ starhub routers [ repurposed as AP/ access points]
might be just under 700 if done correctly
[ with Adguard home / Wireguard/ better QoS , ironically than asusmerlin ] out of the box
TanKianW
All my setup (though not the latest and greatest AX series): Click HERE
I will say GL-iNet routers served me really well during travel. WireGuard VPN, SQM, VLANs, AdGuard Home and extroot config, all in a small package. Perfect for the network nerd on the move! :ROFLMAO:
The latest deployment was during my family trip to hk. :LOL:
BradenHeat
I will say Gli-net routers serve me really well during travel.
nah bei... should have known YOU"RE ALWAYS ONE STEP AHEAD daikor
@xiaofan see la, triggered this laojiao show off la
@TanKianW have you tried their main routers ?
really tempted with the cheap offerings, if they hit the 4x4 performance as set by asus rog-gt routers
really, the more we spend, the more we learn.
and some of the recommendation threads, i dare say, can scrap and just buy gl-inet routers, if downloading at high speed isnt priorty,
this saves ALOT of headaches and its more portable
openwrt, amazing it has come a long way from the haydayz where i struggled with tomato :s13::s13::s22::s22:
actually online snobs didnt help as well
GLi-net certainly does a good job by customizing OpenWRT to make it easier to use by end users.
And they do have a model without WiFI (GL-MT2500 aka, Brume 2), which may be a better option if you intend to use it as the main router for home network. Slate AX and Beryl AX may be more suitable as travel router.
However, I am more interested to use official OpenWRT distribution myself. I tried to use my Raspberry Pi 400 (by adding a USB gigabit Ethernet adapter from Ugreen) and it worked pretty well. Then I switched to the Intel J4105 Mini PC as it can run more stuff than the Raspberry Pi 400.
TanKianW
Have been recommending it before COVID travel reopen leh, siew kor! :ROFLMAO:
Show off? Definitely not showing off my messy cables in a hotel. Skill and knowledge...maybe a little. ;)
Wait for you to try la. Recently not much time to tinker due to work. If good then post your haphazard review here to share with us. :ROFLMAO:
BradenHeat
any new comers reading this :
in terms of difficulty [ define by me as, time taken to update, setup, wireless and with Adguard home ]
- Gl-iNet routers, especially the travel axt1800, any problems, a quick 15sec button hold does the trick,
setting up, is not hard , especially compared to [ firewalla/ asusmerlin/ Ubiquity ]
its the easiest and most fun i had, from start to finish to daily driving
the HK company really hit home run in terms of functionality and support, unlike Firewalla, with snobs all the time [ im better at coding, therefore this newbie ask stupid question SHOOT ! ]
- next one, is ironically, the Firewalla, purple, to be specific , as fairly difficult, to setup and run out of the box
because it has its own IPS/IDS with adblocking [ though limited] , its a mini-pro-sumer style sorts of all-in-one travel security
however, once dockers are in, and you start trying out and customizing, Firewalla's terminal [ im a macOS user ] , goes through the roof, if you're not use to [ Dockers ] , its even harder and takes LONGER setup, than having [ with mutiple experiences setup with pals, asusmerlin with custom adguard ]
- last, in terms of time and overall difficulty would be asus merlin,
though its rather straight forward,
the [ messy setup ] from the interwebs, made me , create the all in one thread here, which is still used as reference [ even for myself, when i have to update my buddies' home router ]
the difficulty lies in , pre-work configuration [ knowing which routers are supported and how well ]
getting used to cmd / terminal, ssh remote in, and to setup on the asus router's GUI page first ]
this with the need to run through script by script, asusmerlin customs, are really the uniquely difficult [ starter all in one router ]
as with @TanKianW mentioned in his thread, [ Gl-iNet + OpenWRT , specifically LuCI ] makes it a breeze to " rebound back if a mistake is occured"
Asus merlin, isnt as forgiving, as the router needs to be manually factory reset, and the re-setting of wireless is chewing up 20mins, total, to optimize, + AMTM from the terminal / ssh of merlin, needs time , and total of 1hr plus mostly
again, users who are new, asus routers with support and supportedby merlin, are still great choices, if you're coming from wifi 4/.5
but one has a cheap china, xiaomi- wifi 6 as AP, the GL-slate x or their quad-core line of products would pretty much blow asus out of the water due to functionality with flexibility , including ease of setup
Was looking at Qnap until the price-tag clothesline-and-pedigree my face into the floor mentally [ i short its pricy a.f for wifi6 with specific use case ]
i would avoid using non quad-core CPU, should flexibility comes , 02x slate axt-1800, [ one for home router, one for travel ] is still cheaper and more powerful than standalone setup
[ that was my original intend , for Firewalla purple, with its inbuilt IDS/IPS , but became obsolete due to pricing and the dockers not really that harmonious when setting up
lol
yea la , because i was so entrenched into the initial
[ Ubiquity is prosumer, therefore is great ! ]
to
[ Asus merlin with rog / high end routers are GREAT with adguard ! ]
to
[ Firewalla purple, all in one IDS/ IPS with docker and act as travel router, soon to be end all ]
to now, Openwrt and Gl-iNet,
learned really tons from you and Xiaofan [ thats whom, i got inspiration to built that asusmerlin guide ]
so far, from my previous post,
i can be quite confident and honest,
02 x Slate-axt1800 , can be future proof [ up to wifi 7, as 6e is gonna be looking at cheap AP (xiaomi ) ]
+ existing ISP given wifi routers,
given how much time ive spend, and burned, on dockers and asusmerlin router resets,
OpenWRT' LuCI IS a lazymen's god sent
sgcarousell
thank you for the advise,
at home my phone will back up to a harddisk attached to rpi4 and i also backup to my desktop when i connect it over the weekend while playing some game n stuff. As for "offsite backup", i have another personal harddisk connect to my work pc and my phone back up when i connect to that pc, i m fine with these at the moment will look into nas in future thanks.
TanKianW
Services like nextcloud may be a good fit. Worth considering.
coyote
Anyone here using OpenWRT 18.06.1 on their router?
Kindly share your router brand and model, and experiences.
I'm running Openwrt 18.06.1 on my Mi Router 3G. Loving it.
Will never return to stock firmware again on any router.
What features you get from the open firmware that you don't have in stock?
Hmm, you are replying to a 3.5 years old first post. But anyway, Xiaomi Stock FW is usually very plain and lack of features, not doing justification for the powerful HW (especially later models like Xiaomi AX3600 and Xiaomi AX9000).
Reasons to use OpenWRT: which list quite some features not in Stock FW (eg: Xiaomi, TP-Link, Linksys, etc).
https://openwrt.org/reasons_to_use_openwrthttps://openwrt.org/docs/guide-user/start
In fact, there are many services possible under OpenWRT, but I think for quite some services, it is probably better not to install it within OpenWRT.
https://openwrt.org/docs/guide-user/services/start
For example, you can have Docker inside OpenWRT. But I tend to think it is easier to use another Linux machine (or Proxmox VM) and then install Docker there.
Same for Adguard Home. I use Proxmox LxC container to install Pi-hole or Adguard Home and then use them with OpenWRT.
But this is just my personal preferences.
TanKianW
BTW, there are ways to install NextCloud under OpenWRT but I do not think that is a good choice.
https://openwrt.org/docs/guide-user/services/nas/owncloud
Rather, it is probably install it as a Proxmox LxC container.
Normally, I would prefer either:​
  • Install on a NAS operating system like Synology DS or TrueNAS Core/Scale using Docker/Jail/containers. Since you will want the data back directly onto the NAS with resiliency provided by HDD RAID (5/6/Z)​
OR
  • Install on a hypervisor in a Linux VM (Ubuntu/Debian) using Docker Compose. Can also install Portainer for easy management of your containers within the VM. With the hypervisor backed and replicated onto a network storage server (NAS).​
It is actually amazing that OpenWRT comes with many packages, including packages like snort, squid, haproxy, Tailscale, Tinc and Zabbix, which pfSense also has. It also has quite some packages like Zerotier and Crowsec which do not exist for pfSense.
You can see the list is much shorter for pfSense.
https://docs.netgate.com/pfsense/en/latest/packages/list.html
But I am not so sure if people really run things like Snort under OpenWRT.
And OpenWRT does not have native package for things like ntopng and Suricata, and of course it will have pfSense specific packages like pfBlockerNG-devel.
Something I learned recently.
1) Upgrade all the packages
Code:
opkg list-upgradable | cut -f 1 -d ' ' | xargs -r opkg upgrade
2) upgrade OpenWRT
3) IPv6 and IPv6 for OpenWRT (not for Singtel 6rd though)
