Oppo Reno
Nakedtoes
This phone is not waterproof correct?
Sent from My UNDER ARMOUR UNDERWEAR using GAGT
Phone with moving parts likely no water proofing.. but u see Oneplus 7 pro the internal all are using water resistant material to prevent water seepage.. but still if water damage the warranty is void... even for phone that is certified waterproof up to how many meter and once kana water damage is gone case they wun repair for u unless u pay.;)
limpingsim98
One thing need to take note is although front camera is on the pop up portion. The top line display is basically do not make use of the center portion. Icon is still on most left and right. Making it very hard to read.
One review mention charging cable is USB3. It is not. VOOC charging required this special cable plus the charger. Else the phone will be charge at normal speed. Which is around 2 hours as mention in another review.
oinkoink1999
Aiya I forgot abt the moving part... Thanks. Now I really dunno which phone to get
cscs3
Yes, is type C connector but USB2 transfer speed only.
doki81
They gave you the phone? Or have to return?
need return...... mine review is up to...thought suppose to have 10 reviewers...end up only 8 reviews?
Sent from Samsung Exploding Not 9? using GAGT
cscs3
PIxel... or pocophone with gcam... xiaomi with gcam or OP 7 with Gcam.. n4owadays it is more about image processing.
Yes, you are right. Only few ccd sensor maker in the world. Rest is how the image been processed. Also, the lens quality is important.
boaboy
Hi anyone got lobang to buy case that is fully cover the top ? I dun take selfie so rather covered up the whole thing for maximum protection
human_shieldz
The shark fin only for selfie? I thought it serve some purpose for back camera too
Nakedtoes
I dun think manufacturer will come out case for yr special needs.. maybe u need to try other case from other models or brands.:s22:
boaboy
Ya hor the popup is oso for the flash light. Wondering any other way to protect it. Now i paste a scotch tape over it to prevent scratch but looks bad lol
doki81
you change your phone 3 years once? No need to be too protective...android phone no matter how tip top condition also no resell value...worst case...the battery inside bloated after 1 year plus usage...protect till 99 mints condition will still render it useless :(
boaboy
Eh, i would say i change phone fast. Thus need to protect it well so can sell off easily. I take gd care of all my phones. That's just me and my thinking.
doki81
unless you selling within 3 months time after launch...android phone no value after 3 months launch...use the free case come with box will be good enough. Most important is practice to handle with care...
