Other uses for ATX PSU mount?
Shahmatt
I am currently planning a build using the Tecware Fusion 2 Air mATX case.
Fusion 2 Air | Tecware High Airflow SFF Mesh Case​
Since I will be using an external laptop adaptor and a DC-ATX board inside the case, I will not be using the ATX power supply mount.
As such, this mount will be empty, and I want to make some use of it, preferably as a means to mount some 2.5" drives.
Does anyone know of an adaptor that might work for this situation? I prefer not to use double-sided sticky tape if it can be avoided.
TanKianW
Measure the dimension, CAD design a custom mount that suit your use case (Eg. TinkerCAD or Fusion 360), slice the model and 3D-print it. Pretty standard for any DIY enthusiast nowadays. You can also outsource the 3D-printing if you do not own a printer.
Been 3D printing all kinds of custom mounts and brackets for my PC and servers for both home and work applications over the past 4-5 years. With the software and hardware getting more and more user friendly (or idiot proof) in recent years, it can generally print right out of the box with zero experience now.​
