So I was running a Z68 setup with the following components previously.
I5-2500K
Asus P8Z68 V PRO
G.Skill Ripjaw F3-10666CL9-8GBXL x 2 = 16 GB
NH-D14 cooler
GTX 770 (Fresh upgrade from GTX 460 SLI)
Acbel 750 PSU
CM HAF-X
Everything is gravy till I decided to downsize to a smaller casing.
Decided to change to a P8Z77 M PRO as I had good experience with ASUS so far.
Everything ported over nicely and when I turned it on, the red DRAM LED stayed on and refused to POST. No beeping sound, nothing.
I have done my research and done the following
1) Ensure RAM seated properly
2) Flashed BIOS to the latest version
3) Tried using single piece ram to boot
4) Cleared CMOS memory
Still no avail..
Anyone have similar experience? Ram incompatibility? any suggestion / help?
Thanks in advance
I5-2500K
Asus P8Z68 V PRO
NH-D14 cooler
Acbel 750 PSU
CM HAF-X
Still no avail..
Thanks in advance
