PC Build Help and Comparison
Charaxz
Build 1: S$2070
i7-8700 (GIGABYTE H310M-DS2)
CORSAIR VENGEANCE LPX 2666Mhz 16GB
Zotac Gaming RTX2070 Mini 8GB GDDR6
WD BLUE 1TB HDD
SAMSUNG 860 EVO 250GB SSD
CM MWE Gold 650W 80+ Gold Modular (Supplier said he will upgrade to EVGA but not sure of what the psu will be)
NZXT H700i
CM MasterLiquid Lite 120 Cooler
Archer T6E AC1300 DB Wireless Pcie Adapter
Build 2 : S$2192
i7 8700 gigabyte b360m d3h
cooler master liquid lite 120 cpu cooler
corsair vengeance lpx 2666mhz 16gb ram kit
gigabyte rtx 2070 windforce
samsung 860 evo 250gb
wd 1tb blue
evga g+ 650w gold
nzxt h400i matte black case
nzxt aer 140mm fan x 2 pcs
Intel AC-9260 (Wi-fi Card)
Please help me compare these 2 builds
bobozhang137
honestly looks the same to me
if i were you ill take the 2nd one with the gigabyte board and gpu
the h310m actually does not differ much from the b360m. But if the price is the same. Id rather go Gigabyte gpu than zotac gpu.
the H700i is a pretty big case. the H400i is a matx case.
That build in the H700i will look weird cause the motherboard is tiny for that case.
rvyne7
i'm planning to build almost exact rig except with your brand choices and casing :p. (for selection #1)
:s12::s12::s12:
