PC build over budget help
kukucumber
Have a budget of 1.1k. Current build I have in mind, even without the case it is already over budget :(
CPU/MB: i5 6500 + GIGABYTE GA-H170M-D3H = $466 (PC Themes)
RAM: Kingston Ram DDR4 8Gb = $63 (PC Themes)
SSD: Samsung 850 evo 256gb = $129 (Lazada)
PSU: Silverstone SFX 450W Bronze = $109 (PC Themes)
GPU: ASUS GTX 1060 3GB DUAL EDITIONS = $349 (PC Themes)
CASE:
TOTAL: $1116
Usage mainly just 1080p gaming, really want to get a gtx 1060 and ssd. Possible?
No monitor/keyboard/mouse/os needed. Can bros help me out. Prefer to get stuff from same place for convenience.
MianBaoFren
Some key points.... why a sfx psu? What casing are u after?
Next, u don't need the ga-h170. What are u going to use the extra pcie ports for? Are u after the possibility of upgrading to a m.2 ssd in the future?
Why a asus 1060? Is that any particular reason why u choose a premium gpu over the budget ones?
If u gonna ahem your os, I suggest u buy from windows software swap at reddit. Lastly... are u going to build yourself or get pctheme to do it? There's an assembly fee of $30. Factor that in.
Edit: if u want to get more performance which I suggest u do, go qoo10 instead of lazada. Lazada has poor sales for this black Friday.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
ZrE0_Cha0s
can mobo it gigabyte h110m-DS2 @396
drop that gpu and look for shopee zotac GTX 1060 6GB tmr. @259 (time sales)
drop that SSD and get OCZ trion 150 240GB @techdeal qoo10. 109.03
psu change to FSP HEXA+ 550W @techdeal qoo10 64.14
use qoo10 coupons to buy.
den case u can choose whichever u want.
MianBaoFren
spiky0180
From PC Themes
CPU + Mobo: i5 6500 + Asus H110M-A M.2 D.4 (401)
RAM: Kingston 2133mhz DDR4 8GB (63)
HDD: Western Digital Blue 1tb (72)
PSU: Superflower Leadex Silver 550W (119)
GPU: Zotac 1060 3gb single fan (299) / palit gtx 1060 3gb (300 from lazada)
SSD: OCZ Trion 150 240gb (98)
Casing: Tecware F3 white (49)
Total: $1,101
kaixax555
hmmm
i5-6500 + Asrock H110M-HDV @386
1x8GB Crucial DDR4-2133 @62
Samsung 850 EVO 256GB @129 (Lazada)
Zotac GTX1060 Single Fan 6GB @389
FSP Hexa+ 550W @68
Tecware F3 @49
Total 1083
I know can get less with Qoo10 but personally don't like Qoo10 :s22:
wwenze
Meanwhile fanbois be like "companies have low profit margin at local MSRP"
IceCreamPoop
My suggestion is just drop to 4th gen for cpu and mobo if in a tight budget, performance difference is really minor across 4th and 6th.
Spend the money u save on a gtx1060 6gb and a nicer case like tecware alpha black. Psu change to what the bros here are recommending as well the FSP Hexa+ 550w.
Confirm can fit below your budget one~
