PC cant startup. need little help.
toheart
hi guys . need some help here. two days ago i on my pc. the fan and psu no sound not moving , so i try using another PSU to try. Psu worked, fan not moving. So i guess maybe my seasonic S12ii 620gb spoilt . i buy another new one same model. plug it on. but still not working. currently no sound no moving no light. and this i dont know which to plug in. im computer noob zzz. which one can help me pls.
RocketBunny
Nigel from pc care and solution. Second floor that one ah? My pc also like same issue
Koenig168
The CPU 8-pin connector (join the two 4-pin connectors together) is not plugged in.
toheart
koenig68 . hi i plug in 2 4pin also not working. i did took out the ram and reslot it. i use other Psu worked. but cant startup. trying my luck doing. really cannot then go sls.
Junken
might be motherboard issue. bring to nigel if you are unable to troubleshoot by yourself.
BananaMilkShake
Plug out everything including ram except 24pin and 8pin. By fan, i suppose u referring to cpu fan since u bought a new psu. Try changing heatsink. Else u can plug case fan to fan header to see if it spins too.
If all fails, its the motherboard. Cheers
