PC Died, need help replace/upgrade parts
sher8853
Able to start PC but after a few mins, BSOD "NMI_HARDWARE_FAILURE"
I dont know which component is more likely to be the one causing the issue but i suspect is the PSU or Motherboard faulty and i'm planning to replace either one of them/both of them.
Being a newbie at hardware, i will need some help here regarding the compatibility and recommended part to upgrade to.
thank you
Specs
i5 4460
Asrock H81M-HDS R2.0
Kingston 8GB Ram
Samsung 850 Evo 250GB SSD
WD 1TB Blue HDD
MSI Gtx970 Armor 4GB
Super Flower Leadex 550w psu
Sharktoon T28 case
Koenig168
You might want to try updating your drivers or reinstalling Windows first (after backing up your data).
