PC does not boot after pressing power on button
silverrealm
Just finished building my PC and it successfully POST for the first time. So i switched it off by holding the power button and prepped my USB stick to install Windows, however, this time it does not start after i press the power button. I tried resetting CMOS and checked all cable connections to no avail.
AMD Ryzen 5 3600
WD Blue SN550 M.2 (2280) 1TB
CORSAIR CMW16GX4M2C3200C16 VENGEANCE RGB PRO
MSI B550M PRO-VDH WIFI ProSeries Motherboard
Cooler Master RR-212L-16PR-R1 Hyper 212
Cooler Master MWE 650 Gold V2 PSU, 80 Plus Gold
Tecware Nexus AIR TG
Nvidia GTX 970
86technie
- Clear CMOS and try again.
- If you have other GPU do try.
Just a tip instead of pressing down the power button to switch it off.
You can use Windows USB install, under repair your PC there is a option to turn off the PC properly.
silverrealm
this is the only GPU i have...am trying my best to scout for a decently priced GPU.
wtfh4x
Try shorting the power button pins on the motherboard, see if that works. I see Tecware case I scared already after the previous guy kena a faulty power button on a new Tecware case.
