PC for Dota2
royfrosty
You cant even see much from a 120fps. There is nothing fast in the game that will see a difference. Unless you play fps games and racing games then yes.
deathman91
i think you will get screen tearing if you arent running a 120hz monitor?
Also, I don't think you will notice any difference between 60 & 120 fps. So why waste the power and generate unwanted heat for you GPU?
Elijahonli
how to set higher fpx, mine is like somehow capped
If u google there is a way to uncap the 120fps
The command is something like maxfps... Something like that, cant rmb exactly liao. I dunno abt u guys but somehow there is no visible tearing when im playing it at 120fps on my 60hz screen. And i prefer to have around 120 fps is because sometimes at 70-90fps can feel abit not so smooth liao
prezioso
fps_max 120.
You need to enable console in dota 2 properties under game library. -console
