Pc keep having usb plug in sound
lalalalalala
try and swap ur devices around, if got sd card plugged in try and remove it. sounds like u got a faulty port
koroshiya8
i also keep having these when plugging in xbox360 dongle... it's connection loose.
kandinsky
I recently had this issue. Unplugged every single peripheral (USB/displays/headphones/speaker/etc) and slowly plug back one by one. Turned out it was my 2nd monitor connection.
Ohayo!
i oso had such problem.. happened when i plug in empty sd card reader :s22:
thought can just leave it plug in all the time
MoneyFace =p
Cheapo ones? Most of them have lousy loose USB plugs. My Transcend one doesn't have such issue.
Ohayo!
No idea, it was bundled with the microsd from Strontium.
Strontium is quite good brand so shouldnt be the case.a
